5 members (rfs56trk, Otto Skorzeny, FAST55, 216wny, Gdads51), 86 guests, and 1 robot.
Topics128,038
Posts1,055,585
#657349 06/25/2010 10:48 PM
Can I run a 6 volt tach on my 1937 216 with a stock generator?Any suggestions on where to buy a new gage?I would consider a custom made one.I have searched e bay but not really finding anything. Thanks in advance.
It's not the speed you travel it's the quality of the trip that matters !!!
Sorry wrong forum !
try www.westach.com. i just got one made up for one of my trucks. for the time being i have it in the dump and it works good. i got the 3" dia. for easier viewing.
Mike,
I know that I was probably looking right at it, but is your tach attached to the steering column? If yes, did you use a metal clamp?
I would suggest one of the vintage Sun tachs. The early model with the bakelite bezel would look most appropriate for a vehicle of that era. Two parts are necessary: the head and the transmitter unit. The transmitter was different for 6 and 8 cylinder engines and for 6 and 12 volts. It also used an odd mercury battery but I believe modern conversions are available.
tim impossible i didnt put it on until after you drove it. ill send pics.
