| | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | Can I run a 6 volt tach on my 1937 216 with a stock generator?Any suggestions on where to buy a new gage?I would consider a custom made one.I have searched e bay but not really finding anything. Thanks in advance.
It's not the speed you travel it's the quality of the trip that matters !!!
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | try www.westach.com. i just got one made up for one of my trucks. for the time being i have it in the dump and it works good. i got the 3" dia. for easier viewing. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike,
I know that I was probably looking right at it, but is your tach attached to the steering column? If yes, did you use a metal clamp?
| | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | I would suggest one of the vintage Sun tachs. The early model with the bakelite bezel would look most appropriate for a vehicle of that era. Two parts are necessary: the head and the transmitter unit. The transmitter was different for 6 and 8 cylinder engines and for 6 and 12 volts. It also used an odd mercury battery but I believe modern conversions are available. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I know that I was probably looking right at it, but is your tach attached to the steering column? If yes, did you use a metal clamp? tim impossible i didnt put it on until after you drove it. ill send pics. | | |
