| | | Forums66 Topics128,154 Posts1,056,831 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I've seen it here somewhere... An in-line resistor to send only 6volts to the gas gauge. but I can't remember where to order one. Any ideas? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | RadioShack is where mine came from. Don't remember the part # though.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There are a LOT of folks who say you MUST have one or you'll burn out your gauge. That's not my experience. When I converted my 55.1 panel from 6v to 12v years ago I didn't put a reducer on any of the gauges (never thought about needing to). I put over 100K on the panel after the conversion without a single problem with any of the gauges. Maybe I was just lucky or maybe it's not really necessary. I don't know, just advising of my personal experience.
| | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Well, I can't figure out why the range of the needle is so much less. It moves, but not as far as the full sweep as intended. Is that a voltage issue? I put a new sender unit 0-30ohm from the local auto part store. It was difficult to get the gauge to work at all. I had to insulate it from the panel as it was originally. So do I need a voltage reducer after all? Or is it something different?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I didn't know you could get a sending unit from a FLAPS. Have you checked the sender with an ohmmeter to make sure it's 30 ohms full and 0 empty? With so much of this stuff being made in china any more, just being new doesn't mean it works right.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... just my opinion here. Since I know I have a good 6 volt guage, and I'm going to 12volts, a $15 reducer(vender price) mounted on one of the guage studs, is still cheap insurance against laying on my back trying to get back under the dash when I should be crusing down the road. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you disconnect the sender lead, you should get full scale. If you ground the sender lead, you should get an empty reading. | | |
