0 members (),
45
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | I have several body bolts the previous owner(s) have broke the heads off of such as for the door mirror and corner cowl tin (61 gmc), would easy outs be the best or what would be a good way to get them out?
Thank you
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you can plug weld a nut on them, it will work better. The heat from the weld will help break the rust and of course a nut is always easier to deal with. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Don't bother with easy-outs. If you break one off there will be hell to pay. I never could understand those things... they actually cause the bolt to expand making it tighter in the threads.
I usually just drill them out. Start with a small drill and work your way up to the size required for tapping. Most of the time they'll spin out from the force of the drilling but if not then I just run a tap through them and I've never had one screw up on me yet.
If they are in blind hole use left-handed drill bits. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you can plug weld a nut on them, it will work better. The heat from the weld will help break the rust and of course a nut is always easier to deal with. I'll second that! This is my preferred method although I don't usually weld a nut on them any more, just build up a little pile of weld and grab it with vice grips. I use a TIG Welder, but I expect a MIG will work and if you're good stick works with a washer and nut. Can't count the number of broken fasteners I've removed this way, it works that well. Grigg | | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 89 | yes left handed drill bits, lots of lube,and hold your tounge just right. lots of time that works good,some times every thing you do go's south. so just keep a open mind, and lot's of bandages handy!
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Ok I will give it a shot, thanks all for the help once again, this is an awsome site for help! | | |
