7 members (Oldcaliforniakid, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65734 09/14/2006 9:44 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | Does anyone knows if the Langdon's Stovebolt Mini HEI will work with the 6 Volts system if so would I be able to us it on a 1958-60 235 Chevy. Thanks | | |
#65735 09/14/2006 10:49 PM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Why not ask these people? It's their product. http://www.stoveboltengineco.com/
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#65736 09/14/2006 10:55 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Aren't those years...'58-'60 12 volt systems?
Stuart | | |
#65737 09/14/2006 11:02 PM | Joined: Mar 2006 Posts: 14 New Guy | | New Guy Joined: Mar 2006 Posts: 14 | 1. They are out for the weekend at a swap meet or something. We called today. 2. The block is from a 1958-1960 but it is in a 1950 vehicle. Sorry for the error. | | |
#65738 09/14/2006 11:50 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | boerdoc,
You have no interest in changing your 1950 system over to 12 volts..an easy do!
Stuart | | |
#65739 09/15/2006 2:10 AM | Joined: Apr 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 34 | Langdon's Stovebolt MiniHEI is probably the very best thing you can do to improve any early Chevy "Six", no more fussing with points, smooth running, etc. etc. so it would be worth the easy switch-over to 12 volts with an alternator instead of a generator, you won't regret it ! | | |
#65740 09/15/2006 2:15 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | What ever you gotta do - do it! I just installed Langdon's mini w/ the optional round coil. It looks somewhat stock and the improvement in idle, throttle response and low speed drivability is AMAZING! | | |
