Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Otto Skorzeny, Tinker5), 183 guests, and 5 robots.
Topics128,274
Posts1,058,436
Members48,490
#65734 09/14/2006 9:44 PM
Does anyone knows if the Langdon's Stovebolt Mini HEI will work with the 6 Volts system if so would I be able to us it on a 1958-60 235 Chevy. Thanks
#65735 09/14/2006 10:49 PM
Why not ask these people? It's their product.
http://www.stoveboltengineco.com/
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#65736 09/14/2006 10:55 PM
Aren't those years...'58-'60 12 volt systems?
Stuart
#65737 09/14/2006 11:02 PM
1. They are out for the weekend at a swap meet or something. We called today.
2. The block is from a 1958-1960 but it is in a 1950 vehicle. Sorry for the error.
#65738 09/14/2006 11:50 PM
boerdoc,
You have no interest in changing your 1950 system over to 12 volts..an easy do!
Stuart
#65739 09/15/2006 2:10 AM
Langdon's Stovebolt MiniHEI is probably the very best thing you can do to improve any early Chevy "Six", no more fussing with points, smooth running, etc. etc. so it would be worth the easy switch-over to 12 volts with an alternator instead of a generator, you won't regret it !
#65740 09/15/2006 2:15 AM
What ever you gotta do - do it! I just installed Langdon's mini w/ the optional round coil. It looks somewhat stock and the improvement in idle, throttle response and low speed drivability is AMAZING!
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
