1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I have a 1953 chevy 3100 I'm restoring. When I took the truck to have it media blasted, they removed the cab. Unfortunately they removed the cab mounting shackles in the rear and lost them. Does anyone know where I can buy new or used ones?
1953 3100 Chevy 5 window 1971 Chevelle SS
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Put an ad in the Truck Parts Wanted section. I've seen rebuild kits but not the entire shackle in reproduction catalogs. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Same thing happened to me, got a pair from Jay in CA, found him the parts for sale forum.
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There are three different styles available so you need to know 3100's are unique: First picture shows 3100 with offset holes. 3600, 3800, 4000's and 6000's use the next picture. 5000 series COE have their own unique type. There are as many as 4 shims and two lock plates (threaded) which go inside behind seat tub. It is a good idea to use them instead of just nuts and flats since they will pull through depending on use. http://good-times.webshots.com/photo/2235943390102454676FUuGUvhttp://community.webshots.com/photo/2379203940102454676qNTFMD | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You can also check with JIMBO. He has an add in the parts for sale section.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | Thanks for your help guys, I will look into it
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thought I saw them in LMC.
Dave
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Sorry, I thought you were talking about the leaf spring shackles. Yeah I've seen them at American classic parts. Here's the part: CMBK5R Here's the page: cab shackles
Dave
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | I also remember another obscure source around the same price. I got my rusty pair from ebay for about 30 bucks with shipping. Try there.
Dave
| | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | Seems like the blasting outfit should be finding and replacing these for you.... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | You can also check with JIMBO. He has an add in the parts for sale section. 1953Chevy, here's a link to Jimbo he's a bit closer to home for you. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
