| | | Forums66 Topics128,187 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 41 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 41 | Hey Bloters,
I just bought a 1955 1st series, one ton. I want to get it on the road and I'm kinda in a hurry to find some modern wheels that will work. I read all the relevant posts my search came up with and I haven't found an answer yet.
Currently it has stock split rims on it, duels in back. I don't have a local shop that will deal with split rims and I'd really like to get radials on this truck.
I've tried three sets of 16" wheels I had access to with no luck, none of them clear the steering. I'd prefer a bigger wheel diameter than 16", but I'm all ears for any and all help with what wheels will work and what trucks they are found on.
I like the duels in rear, but I'm not opposed to singles either.
Thanks again guys and gals.
- Daniel | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 19.5" wheels will likely fit. Check junk yards and look on step vans among other trucks. Some info here, check the Accuride Catalog link and you'll find part numbers if you want to order new wheels. http://www.stovebolt.com/techtips/wheels/Grigg | | | | | Joined: Sep 2009 Posts: 41 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 41 | Thank you very much for your help Grigg! | | | | | Joined: Sep 2009 Posts: 35 New Guy | | New Guy Joined: Sep 2009 Posts: 35 | I have 19.5 wheels with 8R19.5 michelin radial rubber on my 50 GMC 250 1 Ton.............Sweet | | | | | Joined: Sep 2009 Posts: 41 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 41 | Do you know what vehicle your 19.5's came off of? Also, I know modern duely trucks have wheels such that, all six are interchangeable. Is this the case for your wheels? I'm really just concerned about clearance for the steering.
Thank you for you help gmguy! | | |
