Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, Otto Skorzeny, KCMongo), 60 guests, and 5 robots.
Topics128,006
Posts1,055,268
Members48,418
#65502 09/10/2006 1:29 AM
We recently purchased a early 50's Chevy School Bus and we can't identify the engine in it. The number behind the distributor is F0719J while the casing number - is 3836848 and the cylinder heads were 3769716. The casing and cylinder numbers may be switched. Any help identify these would be greatly appreciated.
Still At It
48 Thriftmaster
64 Impala
62 Impala
Half the fun is making the mess!!!!!The other half is figuring out now what do I do?????
#65503 09/10/2006 1:53 AM
3836848 = 1956 235 head
3769716 = 1958-1962 235 engine
You can find these casting numbers at www.inliners.org .They have several lists of casting numbers, good luck !!
1951 3100 Chevrolet
#65504 09/10/2006 1:56 AM
What does it look like?
A two cylinder air cooled, or a flat four cylinder, or an inline 8, or a....
Or perhaps is its just a 6 cylinder? Look at pictures in the gallery and see if you see one like it.
Or post a picture for us to see.
1952 Chevrolet 3800 pickup
---All pictures---
#65505 09/10/2006 2:46 AM
According to my "Chassis and Body Parts Catalog", I have to agree with the assessment that it's a 1958-1962 block.
The engine code "F0719J", according to the book, is a block, cast in Flint, on July 19. It was originally used in a 3100 - 3800 truck with a 3 Speed Transmission.
There might be a date code behind the starter that could pin it down a little closer for you.
#65506 09/10/2006 4:30 AM
Its a six cylinder, with the short covers and the four bolt pattern on the valve covers. I just couldn't find a number match anywhere. I'll check behind the starter in the morning.
Thanks for the help.
Still At It
48 Thriftmaster
64 Impala
62 Impala
#65507 09/10/2006 6:48 AM
still at it, go to the inliners link and click on casting numbers to the left. you will see your block casting number. click on lots of casting numbers at the top,you will go to http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1916-57cast.html
and see your head casting number.
good luck !!
1951 3100 Chevrolet
#65508 09/10/2006 11:48 PM
Thanks for the help!!!!!!! smile
Still At It
48 Thriftmaster
64 Impala
62 Impala
