7 members (TUTS 59, Otto Skorzeny, Phak1, baldeagle, Hambone, dunfire, Rusty Heaps),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65502 09/10/2006 1:29 AM | Joined: Mar 2004 Posts: 33 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 33 | We recently purchased a early 50's Chevy School Bus and we can't identify the engine in it. The number behind the distributor is F0719J while the casing number - is 3836848 and the cylinder heads were 3769716. The casing and cylinder numbers may be switched. Any help identify these would be greatly appreciated.
Still At It
48 Thriftmaster 64 Impala 62 Impala
Half the fun is making the mess!!!!!The other half is figuring out now what do I do?????
#65503 09/10/2006 1:53 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 3836848 = 1956 235 head 3769716 = 1958-1962 235 engine You can find these casting numbers at www.inliners.org .They have several lists of casting numbers, good luck !! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#65504 09/10/2006 1:56 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What does it look like? A two cylinder air cooled, or a flat four cylinder, or an inline 8, or a....
Or perhaps is its just a 6 cylinder? Look at pictures in the gallery and see if you see one like it. Or post a picture for us to see. | | |
#65505 09/10/2006 2:46 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | According to my "Chassis and Body Parts Catalog", I have to agree with the assessment that it's a 1958-1962 block.
The engine code "F0719J", according to the book, is a block, cast in Flint, on July 19. It was originally used in a 3100 - 3800 truck with a 3 Speed Transmission.
There might be a date code behind the starter that could pin it down a little closer for you. | | |
#65506 09/10/2006 4:30 AM | Joined: Mar 2004 Posts: 33 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 33 | Its a six cylinder, with the short covers and the four bolt pattern on the valve covers. I just couldn't find a number match anywhere. I'll check behind the starter in the morning.
Thanks for the help.
Still At It
#65507 09/10/2006 6:48 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | still at it, go to the inliners link and click on casting numbers to the left. you will see your block casting number. click on lots of casting numbers at the top,you will go to http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1916-57cast.html and see your head casting number. good luck !! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#65508 09/10/2006 11:48 PM | Joined: Mar 2004 Posts: 33 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 33 | Thanks for the help!!!!!!!
Still At It
