5 members (Rusted Nut, Southerntruck, MickeyP, mick53, Dennys28), 102 guests, and 3 robots.
Topics128,043
Posts1,055,611
#654906 06/15/2010 12:50 PM
Still struggling to get the rear drums off. I slid the axle shaft out of the hub but I still can not get the drum off. Anyone have any suggestions? Something has to hold this drum on. There is a cover over the center hub that had five small bolts. After taking this cover off I screwed a small fine threaded bolt into the center of the axle shaft and slid it out. Not sure what to do next?
Remove the large nuts and locking washer and then drum, hub, bearings and all should slide out.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Thanks. I also found a real detailed previous post from freq2002 which helped!
