| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Still struggling to get the rear drums off. I slid the axle shaft out of the hub but I still can not get the drum off. Anyone have any suggestions? Something has to hold this drum on. There is a cover over the center hub that had five small bolts. After taking this cover off I screwed a small fine threaded bolt into the center of the axle shaft and slid it out. Not sure what to do next? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | After taking this cover off I screwed a small fine threaded bolt into the center of the axle shaft and slid it out. Not sure what to do next? Remove the large nuts and locking washer and then drum, hub, bearings and all should slide out. Grigg | | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Thanks. I also found a real detailed previous post from freq2002 which helped! | | |
