3 members (GIJOE298, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
have a 49 Model 3100 with original 216 engine with a Carter W 1 carb. The carb has been rebuilt twice and er still can't get the engine to run right. There is also a Carter YF model carb, is there any advantage, the W1 one over the YF, id so what? I'm thinking of going to a rebuilt YF carb, what is your thoughts and recommendations. Thanks.
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
Whats the engine not doing right ,I just rebuilt a W1 and installed it on my 52-3100 with 216 and it never ran this good if you could tell me what wrong I might be able to help.
Pete
Y
Y Offline
describe how it is not running correctly and we can probably figure it out, I am sure someone here has run into the same issue.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Carburetion specialist
The Carter YF is one of the most technologically advanced 1-barrel carburetors ever produced, at any price, anywhere in the world! (My opinion, others may differ) Variants of the YF were among the last carburetors to be used in the USA when fuel injection finally replaced the carburetor due to emission issues. The YF production run: 1950 to about 1990!!! Pretty impressive.
Unfortunately, the YF uses a neopreme diaphragm accelerator pump. With deathanol, the diaphragm does not hold up so well as in gasoline. For "daily drivers" expect to replace the diaphragm every 2~4 years. For "hobby" use, the failure will be more often.
The W-1, while slightly below the technology level of the YF, is much more friendly to the use of fuels other than gasoline. The leather accelerator pump is impervious to deathanol. Once properly rebuilt, the W-1 is virtually bullet-proof, assuming the owner changes fuel and air filtering at recommended intervals.
Jon.
The Carburetor Shop
Carbking,
Are all the YF's the same? Any certain year better than other for say.... running of a later model 235? And where can you buy one in good condition without spending an arm and a leg?
~Thanks
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
Carbking:
Do you know where I can get a rebuilt Carter YF or W1. I need to get this truck on the road and the carburetor has help us up. Problem is that we have rebuilt it three times and it works for a bit then begins to foul up. I have ordered an in line fuel filter, but I need a dependable carburetor. Please advise. Thanks.
Dave
Put an ad in Truck parts wanted I just bought two W1 s there and rebuilt one and the truck runs great.
Pete
Sounds like you found your problem with your W-1, i.e., "I have just ordered an in line fuel filter".
DG
Denny G
Sandwich, IL
