1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | have a 49 Model 3100 with original 216 engine with a Carter W 1 carb. The carb has been rebuilt twice and er still can't get the engine to run right. There is also a Carter YF model carb, is there any advantage, the W1 one over the YF, id so what? I'm thinking of going to a rebuilt YF carb, what is your thoughts and recommendations. Thanks.
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Whats the engine not doing right ,I just rebuilt a W1 and installed it on my 52-3100 with 216 and it never ran this good if you could tell me what wrong I might be able to help.
Pete | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | describe how it is not running correctly and we can probably figure it out, I am sure someone here has run into the same issue. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The Carter YF is one of the most technologically advanced 1-barrel carburetors ever produced, at any price, anywhere in the world! (My opinion, others may differ) Variants of the YF were among the last carburetors to be used in the USA when fuel injection finally replaced the carburetor due to emission issues. The YF production run: 1950 to about 1990!!! Pretty impressive.
Unfortunately, the YF uses a neopreme diaphragm accelerator pump. With deathanol, the diaphragm does not hold up so well as in gasoline. For "daily drivers" expect to replace the diaphragm every 2~4 years. For "hobby" use, the failure will be more often.
The W-1, while slightly below the technology level of the YF, is much more friendly to the use of fuels other than gasoline. The leather accelerator pump is impervious to deathanol. Once properly rebuilt, the W-1 is virtually bullet-proof, assuming the owner changes fuel and air filtering at recommended intervals.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | Carbking,
Are all the YF's the same? Any certain year better than other for say.... running of a later model 235? And where can you buy one in good condition without spending an arm and a leg?
~Thanks | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Carbking:
Do you know where I can get a rebuilt Carter YF or W1. I need to get this truck on the road and the carburetor has help us up. Problem is that we have rebuilt it three times and it works for a bit then begins to foul up. I have ordered an in line fuel filter, but I need a dependable carburetor. Please advise. Thanks.
Dave
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Put an ad in Truck parts wanted I just bought two W1 s there and rebuilt one and the truck runs great.
Pete | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sounds like you found your problem with your W-1, i.e., "I have just ordered an in line fuel filter".
DG
Denny G Sandwich, IL
