0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#652934 06/07/2010 5:07 AM
I've read every thread here, and many elsewhere, and nobody seems to specifically say anything about using adapters like these: Adapters on the front wheels. Can I get some more opinions? They seem like they would be safer than spacers, at least. I know that the best thing would be to just get proper backspaced wheels, but as a lower cost alternative, I keep coming back to this.
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
I’ve used these adaptors for over 8,000 miles now with no problems.
1” Adaptors mounted to ’50, 3600.
http://www.pbase.com/dennygraham/image/125319625/large
Rework center to fit ’70 3/4-ton Chevy wheels.
http://www.pbase.com/dennygraham/image/125319633/large
They’re not inexpensive and if I had it all to do over again, I would probably have had wheels made with the proper offset and not used the adaptors. It would have cost less than I spent on the wheels I now have and adaptors.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I run Dodge and Ford wheels on the front of my trucks with no problems.I have about 1/4 in. clearance between the wheel and tierod.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Denny - Why did you need to rework the center? Was it that inner ridge was too thick to get the newer wheels over?
That was all it was, the od of the center pilot was about .010" to big for the wheels.
DG
Denny G
Sandwich, IL
Why are those adapters so expensive? Wow that's a lot of money for just one adapter.
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
They're limited production and machined to close tolerance Casey. Also the two blank aluminum billets for my 3/4" ton (8" x 1.5") would run around $100 and the studs would be in the $25 to $30 range. Throw in a set of lug nuts and you're looking at somewhere around $150 before the enginering or machineing even starts.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I had adapters on the rear of 54 for 18 years with no trouble. Now i have spacers for offset.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
just my two cents worth ,but i ran adapters on the front of 1/2 ton once and one broke off ...just very lucky i was going at a slow speed ....they might be better now ,but no more for me .
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
