0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 78 | I've read every thread here, and many elsewhere, and nobody seems to specifically say anything about using adapters like these: Adapters on the front wheels. Can I get some more opinions? They seem like they would be safer than spacers, at least. I know that the best thing would be to just get proper backspaced wheels, but as a lower cost alternative, I keep coming back to this. 1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I’ve used these adaptors for over 8,000 miles now with no problems. 1” Adaptors mounted to ’50, 3600. http://www.pbase.com/dennygraham/image/125319625/large Rework center to fit ’70 3/4-ton Chevy wheels. http://www.pbase.com/dennygraham/image/125319633/large They’re not inexpensive and if I had it all to do over again, I would probably have had wheels made with the proper offset and not used the adaptors. It would have cost less than I spent on the wheels I now have and adaptors. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | I run Dodge and Ford wheels on the front of my trucks with no problems.I have about 1/4 in. clearance between the wheel and tierod.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Nov 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 78 | Denny - Why did you need to rework the center? Was it that inner ridge was too thick to get the newer wheels over? 1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That was all it was, the od of the center pilot was about .010" to big for the wheels. DG
| | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Why are those adapters so expensive? Wow that's a lot of money for just one adapter. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | They're limited production and machined to close tolerance Casey. Also the two blank aluminum billets for my 3/4" ton (8" x 1.5") would run around $100 and the studs would be in the $25 to $30 range. Throw in a set of lug nuts and you're looking at somewhere around $150 before the enginering or machineing even starts. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I had adapters on the rear of 54 for 18 years with no trouble. Now i have spacers for offset.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | just my two cents worth ,but i ran adapters on the front of 1/2 ton once and one broke off ...just very lucky i was going at a slow speed ....they might be better now ,but no more for me . | | |
