0 members (),
91
Mod | | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | Please help
Just movedinto california, brought my 1965 c10 too be reregistered. DMv canot identify nnor verify vin... where else can i find it before i go too highway patrol too have it located. thanks guys | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The vin plate should be located on the upper left door hinge pillar. It may also be stamped on the frame, I'm not 100% sure about that on the later trucks, though.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Dawg65 The highway patrol should know where to look, they did on my 54 3100... Made a big deal about the secret location...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | 1955 was when they started stamping the frames, before that, it was on a tag. Also, they used the engine serial number for the vin number.
Joe | | | | | Joined: Mar 2010 Posts: 76 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 76 | your vin tag is right over your head as you enter the cab on the drivers side. if you don't see it check under the hood just over the heater box . I have a 66 with the vin in that location. it looks totally factory (weird). you can figure out your vin by creating the first 5 letters c1545 long bed or c1445 short bed. the rest of your vin is located on the frame rail under the hood between the radiator and the exhaust manifold on the drivers side.good luck! | | |
