4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#651514 06/01/2010 8:26 PM
Please help
Just movedinto california, brought my 1965 c10 too be reregistered. DMv canot identify nnor verify vin... where else can i find it before i go too highway patrol too have it located. thanks guys
The vin plate should be located on the upper left door hinge pillar. It may also be stamped on the frame, I'm not 100% sure about that on the later trucks, though.
Bill Burmeister
Dawg65 The highway patrol should know where to look, they did on my 54 3100... Made a big deal about the secret location...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
1955 was when they started stamping the frames, before that, it was on a tag. Also, they used the engine serial number for the vin number.
Joe
your vin tag is right over your head as you enter the cab on the drivers side. if you don't see it check under the hood just over the heater box . I have a 66 with the vin in that location. it looks totally factory (weird). you can figure out your vin by creating the first 5 letters c1545 long bed or c1445 short bed. the rest of your vin is located on the frame rail under the hood between the radiator and the exhaust manifold on the drivers side.good luck!
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
