| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 22 Apprentice | | Apprentice Joined: Jan 2010 Posts: 22 | I recently got a 1960 Oldsmobile transmission to mate to my 1956 Oldsmobile Super 88 324 V8 4 barrel. The guy I bought it from claims it's rebuilt. It wont upshift unless I take my foot of the gas momentarily and will then shift very smoothly.It also wont shift back down to first until I'm almost at a stop. Now I know the downshift linkage is out of whack. So I'm guessing thats the reason for my second problem but does anyone have any thoughts on it's upshift problems?
-Mitch
If the frame is Good then everything else can be fixed. 1930 Chevy 1/2 ton (Sold her) 1948 Ford f-5 (Shot her) 1951 Willys-Overland Wagon (Lost her) 1959 Chevy Apache Fleetside (Left her) 1956 Oldsmobile Super 88 (Drive her)
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The throttle pressure linkage is slightly out of adjustment. Try shortening (or lengthening) the adjustable rod connected from the carburetor linkage to the bellcrank on the transmission. This controls the point where upshifts and downshifts happen. More throttle pressure delays the upshift until a higher speed is reached, but it also will make the downshivt happen sooner. Try reducing the idle speed to help with the shift to 1st. gear at a stop, and drop the throttle pressure to make the upshift happen sooner. The "Controlled Coupling" Hydramatic (No, it's NOT a Jetaway) is VERY picky about throttle pressure adjustments Jerry
| | | | | Joined: Jan 2010 Posts: 22 Apprentice | | Apprentice Joined: Jan 2010 Posts: 22 | Thanks Jerry, But are you sure it isn't the Jetaway? 1956 was the transition year from the regular Hydramatic to the Jetaway Hyrdamatic then in 61 it switched to the 2 speed aluminum case I think they nicknamed it a Slim Jim. Mine has the cast iron case and looks Identical to my 56 transmission besides the oil pan size is smaller and tail shaft is 4 inches shorter. The shop manual I have is for the 56 and gives me a very broad run down on how the linkage works not how to adjust it. I think the engineers didnt even know how to do it.
