0 members (),
69
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | While out for a short drive last night in my '53 3100 (216) I rode home on the back of a tow truck. While going up a slight grade, the engine missed a couple times and quit. It would restart, but only for a second or so. Got up this AM and she started first try and runs great, but with an intermittent miss. Any opinions on what is going on.....fuel filter, trash in carb? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Those are both good likely causes. another could be the coil going bad. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | explain the coil......just replaced it a month ago. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I made an assumption that it would be old. That doesn't mean that a new coil is any good though. They can be tested with a volt/ohm meter, just google it. | | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | Years ago I was plagued with a similar problem. After trying all sorts of things with no results, it turned out to be a flaky ignition condenser. This is about the cheapest and easiest thing to replace on the whole truck, so give it a go. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Had the same problem with the condenser in the dist. + I would have that coil checked
dan-pa
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I had a similar problem with my 53 3100 with a 235. It would idle in the driveway for as long as I had patience, but I could only drive it about 1/2 mile before it would die. It was a almost completely clogged fuel line from the tank to the fuel pump. Only enough flow to barely fill up the bowl while idling. Then it would run dry when I tried to drive.
For your consideration, Leon | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Leon... I had a similar problem with a 76 motor home we inherited from my father-in-law. It would run well on level ground, but wouldn't climb a hill. Ol' Stan used to complain about clogged fuel filters all the time, so when it acted up on a cross-country drive, I pulled over and tried to change it. There was a new spare in the glove box. I put the new one in the way the old one came out, and the engine ran well for a while, then acted up. As I was being jerked back and forth in the driver seat I thought about how the small, thimble-shaped was situated in its mount. The closed end was facing the gas line. I started to think that maybe that wasn't right. I stopped and flipped the filter around to see if things would improve. Well, the old 454/4bbl started pushing that shoebox-on-wheels uphill faster than I was ready for! It's absolutely amazing how a trickle of fuel can fool you into thinking everything is alright at idle or low load, but will make you tear your hair out when trying to make speed! Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
