1 members (baldeagle),
43
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65050 08/30/2006 1:28 PM | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | I know this may sound stupid but do I use modern day antifreeze in my 42 pick up or do I need something else? My shop manual calls for glycerine and ethylene glycol or denatured alchol. I should have her up and running for the first time in 5 or 6 years. my truck http://www.picturetrail.com/gallery/view?p=999&gid=9015746&uid=4287994&members=1 | | |
#65051 08/30/2006 2:14 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Ues the new stuff. Add a bottle of waterpump lube. Wow, nice paint job. Our gang will be coming down from the Syracuse area to Little York, Cortland, Ny on 17 Sept for the show. I'll have a 52 Chevy 1/2 ton, dark red color. Look us up.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#65052 08/30/2006 3:02 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You should be OK using modern antifreeze. I use it in my 38 without problem.
#65053 08/30/2006 3:33 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I doubt you can even buy alcohol based anti-freeze nowadays. I haven't seen it in 25-30 years. One thing you may want to consider is adding a wetting agent. It breaks down the surface tension of the anti-freeze and water mixture and really does help in cooling. Most of the street rod guys use it with hi-pro engines that make a lot of heat. | | |
#65054 08/30/2006 3:36 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | The mix ratio for a GM should be 50/50. At least that’s what the chart at the store said. | | |
#65055 08/30/2006 4:06 PM | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Standard green antifreeze is ethylene glycol and rust inhibitors. It should work fine at a 50:50 mixture with water. This ratio provides nearly the optimal ly low freeziing point and highest boiling point. (I think the actual optimal mixture is something like 56% ethylene glycol, but there is little difference in the freezing point supression and raising of the boiling point. So, the easy ratio to remember and make, 50:50, is used.)
58 Fleetside, 235, "The Old Buckin' Bronco"
#65056 08/30/2006 4:22 PM | Joined: Jun 2005 Posts: 2 Junior Member | | Junior Member Joined: Jun 2005 Posts: 2 | Be careful which "modern" antifreeze you use. Standard green ethylene glycol-based antifreeze is fine. Other modern antifreeze such as Organic Acid Technology (which is pink if I recall correctly; used for a while on some Ford products) and orange Dexcool can attack some gasket materials. This is one reason not all coolants are backwards compatable. | | |
#65057 08/30/2006 4:45 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | and some of the other colored stuff cost more Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#65058 08/30/2006 4:51 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | You can still get alcohol-based antifreeze.
I don't know where, but Grandpa still runs it in his old tractors (he has five).
-Brendan | | |
#65059 08/30/2006 6:37 PM | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Alcohol anti-freez was/is basicly "Denatured" alcohol.... more commonly known today as "Rubbing" alcohol....... and you can buy it at amy pharmacy...
Another product that you see alot of these days.. is "HEET", gas-dryer... is also nothing more than denatured alcohol... so instead of paying a couple bucks for HEET at the auto-parts store.... just stop by your local Walgrens/CVS pharmacy.. and pick up a pint of rubbing alcohol for 50 cents.....lol
Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#65060 08/30/2006 7:53 PM | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Thanks so much for the info. | | |
#65061 08/31/2006 6:33 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | be carefull, most not all rubbing alcohals have much water in them 30% and more. and i don't know what isopropal (another rubbing alcohal) will do the fuel system parts. Old time antifreeze was methanol, also known as wood alcohal.
"It ain't a truck if you can't hose out the cab."
