9 members (Samantha, Forty9, texas46, Rustnut, IHPWR, Bill Hanlon, DadsFirstPickup, 32Fordpuchoptop, 1 invisible), 140 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
#649690 05/25/2010 11:54 PM
jmh
Offline
Hi All,
Not having much luck in finding rear spring pins and bushings for my 48 Loadmaster.While you all are helping me with this here is another "I cant find" item.My truck has a cable system for the emergency brakes.Where do I find the cable and clevises for replacement?
JMH
I have 2 NOS brake cables for 1948 models; RJ, RK, RV, RW with inside gas tank. These are 58 1/4" long E-mail me if interested [email protected]
For the spring items I would try Espo Spring and Things.
1951 1 Ton Completed
or since your close by down in Ga. you may want to give Spring Service and Alignment in Greenville, S.C. 864-299-3340
jmh
Offline
Thanks for the offer. My truck has the external tank.Is there a difference.I also found out that I am missing the linkage that attaches to the brakes themselves. I need to remove a drum and check things out.
JMH
