| | | Forums66 Topics128,186 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 25 Apprentice | | Apprentice Joined: Nov 2009 Posts: 25 | Hey guys. I need some ideas on swapping from 6lug to 5lug. I have a 49 3100 with all orginal tranny to rearend setup. Also need a higher gear ratio. Wanting to go the least expensive way of course also. Thanks in advance.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I used the rear from a '73 Chevelle wagon with 3.08 gears under my Suburban. I've been real happy with it except the one time I tried to pull a trailer with it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The least expensive would be to locate a FREE 3:55 ratio car rear end say, 1951-54. These were in cars with the powerglide trans. I have a tech tip on this you can check out. The very best way is to ditch the torque tube and go open drive line and then a zillion better ratio rear ends could be used. | | | | | Joined: Nov 2009 Posts: 13 New Guy | | New Guy Joined: Nov 2009 Posts: 13 | I have a 10 bolt rear in my 53 with 3.55 gears, I'm putting a 350sbc and th350 trans in. I'm very curious to drive this and see what its like.
A friend will bail you out of jail, but a real friend will be sitting next to you in the cell saying we really F*****up this time.
| | | | | Joined: Nov 2009 Posts: 25 Apprentice | | Apprentice Joined: Nov 2009 Posts: 25 | thanks JiMerit and OldSub on the info. I am looking to do away with the torque tube and all. I am running a 235. What would be nice if i could keep my column shifter, have open drive line, a higher gear for better speeds and 5 lugs. Ha Is this possible? or am i dreaming?
Ive got access to a 66 chevelle 4 door with a straight six in it. Its got 3 speed on the column i believe. dont know what size the motor is though. Would the drivetrain bolt up to my 235 i wonder? I will be searching on here for more info.
