5 members (Gray_Ghost, frogfarmer, Otto Skorzeny, jay d, 50Chevy3100), 52 guests, and 3 robots.
Topics128,056
Posts1,055,804
#649203 05/24/2010 2:02 PM
SPL
Offline
Lever shock filler plugs are froze solid. Vice grips, penetrating oil and normal methods to loosen have not worked. Any other ideas?
SPL #649258 05/24/2010 5:46 PM
Have you tried heat. Had to do that on mine. Asmall torch will work fine.
46forme #649275 05/24/2010 6:29 PM
SPL
Offline
I would be interested in how you did it. I hesitate to heat the plugs since the shocks are mounted and have oil in them. Is there a rubber seal at the plug that would get damaged with heat? Does the cover have to taken off and the shock drained before heat is applied?
