| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 27 New Guy | | New Guy Joined: Apr 2010 Posts: 27 | Lever shock filler plugs are froze solid. Vice grips, penetrating oil and normal methods to loosen have not worked. Any other ideas? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Have you tried heat. Had to do that on mine. Asmall torch will work fine. | | | | | Joined: Apr 2010 Posts: 27 New Guy | | New Guy Joined: Apr 2010 Posts: 27 | I would be interested in how you did it. I hesitate to heat the plugs since the shocks are mounted and have oil in them. Is there a rubber seal at the plug that would get damaged with heat? Does the cover have to taken off and the shock drained before heat is applied? | | |
