0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#646942 05/16/2010 2:21 PM
Is there a trick to locating the screw holes for the visors once the headliner is on? Looking back I should have made a template to reference where they were on the A pilar. The headliner did not fit properly so I am glad that I did not pre drill the holes.
Here is what worked for me:
- Get 6 cheap screws of the correct diameter (3 for each side).
- Grind the heads off the screws to obtain a tapered point at the top of each screw.
- Screw the screws into to the holes, leaving them out a little.
- Put the headliner into place and press the headliner onto the tapered screw-heads. Remove the headliner, drill-out the screw holes, and cut-out a hole between the three screws (so the pivot in the visor arm).
- Install the headliner and screw-in the visor arms.
- Have a beer or a cup of tea and admire your work.
Bob, I made a template of the holes on the driver side and just flipped it around to the passenger side, using an ice pick I picked up one of the holes then it was easy to find the other two.
http://www.pbase.com/dennygraham/image/124610432
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Sounds like a logical and simple technique, Denny. I'll check the headliner sets that I got for my regular cabs and if they already have holes on the driver's side of the headliner, this will be easier than I described.
The headliner sets that I got for the Suburban had no holes on either side of the headliner (and, at that time, I had no new set for a regular cab). I guess that necessity was the mother of invention.
Tim, I get from you reply that you were transfering the holes "when you were installing your headliner".
I think Bob already has the headliner installed and he was trying to locat the pre-drilled holes in the pillar behind the blank cardboard. The holes should already be in the pillar, mine were in my '50.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
If Bob has a headliner that is already installed and the headliner is already pre-drilled on the driver's side, your technique is excellent, Denny. If Bob's cardboard headliner is not pre-drilled for the driver's side visor (my cardboard headliners came with no holes for visors on either side), he would have no pattern to transfer to the other side.
Every A-D and ND cab I have seen (regular cab and panel body) was pre-drilled for visors on both sides (in the sheet metal above the pillars).
My headliner is in, and my new visors are in a drawer because of this. If someone comes up with a solution, I'm all ears.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Nothing is fool-proof to a talented fool. Unfortunately I believe that you will have to take the headliner back out to make a successful installation template. Tim seems to have a good idea in my humble opinion.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Make a template from someone elses truck.There is plenty of trucks without headliners out there.Maybe a fellow stovebolter in your area could help you out?
Thanks for all of the tips. There is a long story behind the headliner installation...I'll spare you the long story but it just did't fit right...spaces gaps on the front, back and sides! For now I used Denny's suggestion with the ice pick and it worked great. New question for you now...when I put the new cardboard visor on the rod which is secure the visor just flops around. Is there a good way to crimp these or am i missing a part that would hold them snug to the rod? Thanks again for the help!
I believe there should be a long curved piece of spring steel in the visor that holds it tight to the rod.
DG
Denny G
Sandwich, IL
You are correct, but the there is no real pressure between the rod and the sleeve inside the visor. I almost want to try and crimp it a bit but that would probably score / crush the exterior of the visor. I'll keep at it and let you know what I figure out...should be on the road by mid June. All the body work and engine are done now. just a few things with the trans and differential which I am having a pro look at. Thanks!
I'm not sure, but I was told to give the rod a slight bend to tighten it up to the rod.
If this is not right I'll definitely be told so.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Moderated by  ndkid275, Phak1
