3 members (2-Ton, kbenz, MNSmith),
161
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | Is there a trick to locating the screw holes for the visors once the headliner is on? Looking back I should have made a template to reference where they were on the A pilar. The headliner did not fit properly so I am glad that I did not pre drill the holes. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is what worked for me:
- Get 6 cheap screws of the correct diameter (3 for each side).
- Grind the heads off the screws to obtain a tapered point at the top of each screw.
- Screw the screws into to the holes, leaving them out a little.
- Put the headliner into place and press the headliner onto the tapered screw-heads. Remove the headliner, drill-out the screw holes, and cut-out a hole between the three screws (so the pivot in the visor arm).
- Install the headliner and screw-in the visor arms.
- Have a beer or a cup of tea and admire your work.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bob, I made a template of the holes on the driver side and just flipped it around to the passenger side, using an ice pick I picked up one of the holes then it was easy to find the other two. http://www.pbase.com/dennygraham/image/124610432 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sounds like a logical and simple technique, Denny. I'll check the headliner sets that I got for my regular cabs and if they already have holes on the driver's side of the headliner, this will be easier than I described.
The headliner sets that I got for the Suburban had no holes on either side of the headliner (and, at that time, I had no new set for a regular cab). I guess that necessity was the mother of invention.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim, I get from you reply that you were transfering the holes "when you were installing your headliner". I think Bob already has the headliner installed and he was trying to locat the pre-drilled holes in the pillar behind the blank cardboard. The holes should already be in the pillar, mine were in my '50. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If Bob has a headliner that is already installed and the headliner is already pre-drilled on the driver's side, your technique is excellent, Denny. If Bob's cardboard headliner is not pre-drilled for the driver's side visor (my cardboard headliners came with no holes for visors on either side), he would have no pattern to transfer to the other side.
Every A-D and ND cab I have seen (regular cab and panel body) was pre-drilled for visors on both sides (in the sheet metal above the pillars).
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | My headliner is in, and my new visors are in a drawer because of this. If someone comes up with a solution, I'm all ears. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Nothing is fool-proof to a talented fool. Unfortunately I believe that you will have to take the headliner back out to make a successful installation template. Tim seems to have a good idea in my humble opinion. | | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | Make a template from someone elses truck.There is plenty of trucks without headliners out there.Maybe a fellow stovebolter in your area could help you out? | | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | Thanks for all of the tips. There is a long story behind the headliner installation...I'll spare you the long story but it just did't fit right...spaces gaps on the front, back and sides! For now I used Denny's suggestion with the ice pick and it worked great. New question for you now...when I put the new cardboard visor on the rod which is secure the visor just flops around. Is there a good way to crimp these or am i missing a part that would hold them snug to the rod? Thanks again for the help! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I believe there should be a long curved piece of spring steel in the visor that holds it tight to the rod. DG
| | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | You are correct, but the there is no real pressure between the rod and the sleeve inside the visor. I almost want to try and crimp it a bit but that would probably score / crush the exterior of the visor. I'll keep at it and let you know what I figure out...should be on the road by mid June. All the body work and engine are done now. just a few things with the trans and differential which I am having a pro look at. Thanks! | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I'm not sure, but I was told to give the rod a slight bend to tighten it up to the rod. If this is not right I'll definitely be told so. | | |
