| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I bought a 4 barrel 600cfm carb off of Ebay awhile back. I gave it a rebuild kit (I've rebuilt a few without any problems) but this one is acting funny. The truck fires up right away, but instead of going down to idle, it keeps reving up! After revving really high the motor dies. I have a few theories.
1. The floats need to be adjusted 2. The secondaries are stuck open on the carb gasket 3. I really screwed up the idle adjustment screw
Anyone have any experience with this? | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | That carb has vac secondarys. Adjusting the float is not hard, a little low to start would be better than high, once it's idleling fine you can readjust the float. I'd start with idle screws turned out 1 1/2 turns, that should let it run at least. Why it wants to race kinda says it's getting gas from somewhere until it uses it up and shuts down. I think I'd pull it off and re check what I did to make sure things are the way they are supposed to be. At least a holley is simple to tear down. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Gas cannot make the idle speed up, only air. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Gas cannot make the idle speed up, only air. When the choke is partially closed, the engine gets more fuel/less air and the engine idle speed goes up. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Builder;
It's kinda both. When the choke is closed it opens the throttle plates via linkage to give a fast/high idle. Regardless I can't figure out why the engine would start, rev high and then die. It's almost like it has both an air and fuel problem. Hope to see the solution on this thread.
SimS | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Vac leak I would check to see if You have any vac leaks it's common that if theres a vac leak the engine will use the gas thats in the manifold than will not get gas from the carb because of a lack of soction from the engine thru the carb so You get the high RPMs than nothing
Pete
| | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Ok, well, I guess I'll try the floats and the Idle screw first. I really do not want to go through and rebuild the carb again if I can help it. I'll check for vacuum leaks too, but that will be hard if I only have a few seconds to check it while its running. Wow, it could be a lot of things. Getting down to the bottom of this may prove difficult.
I'm not sure I understand this quote: "Vac leak I would check to see if You have any vac leaks it's common that if theres a vac leak the engine will use the gas thats in the manifold than will not get gas from the carb because of a lack of soction from the engine thru the carb so You get the high RPMs than nothing"
You say there is gas in the manifold, why would there be gas in the manifold upon start-up, besides maybe one pull from the carb? My truck will run for about 10-15 seconds, even if there was gas in there to start it wouldn't last 10-15 seconds.---
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When You pump the carb to set the choke the acc. pump dumps some gas into the manifold but here isn't suction because of a vac leak she will not keep running.I had this happen on a SB the engine backfired and took out a small section of the intake gaskit.
Pete
| | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Problem solved. Turns out it was just the carb gasket was covering up a few ports on the bottom of the carb. I took a razor blad and cut the gasket on the inside and problem solved. | | |
