| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Just wanted to get an idea of what people have used for their wood in their bed. I'd really like a light color for contrast (pine, ash) but i'd also like a decent durability. I didn't wanna buy a pre-cut kit; i can do the cutting and milling myself and save. Any suggestions or pictures of finished products? Thanks | | | | | Joined: Mar 2009 Posts: 91 New Guy | | New Guy Joined: Mar 2009 Posts: 91 | white oak is strong and light (in color) and would be better than pine or ash IMO. As for a finish, it depends are you won't a show finish or a finish to use the truck as a truck? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used Hickory in mine DONT GET MUCH HARDER THAN THAT ..LOL..pics in photobucket.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The original yellow pine that came in the truck has lasted for how many years? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Yellow pine is your best bang for the buck. | | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | yellow pine...it is the original and best
Craig 1946 Chevy Mod Truck
| | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Where can one go to get yellow pine though? The original yellow pine was old growth wood which is not available anymore except as a reclaimed wood if you can find it... | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Things to consider when selecting wood for a truck bed.
1. How will you use it? 2. Will it be stored inside or outside? 3. Originally they were painted black. Do you want a painted bed?
For my truck, which I leave outside, and use for hauling building materials, I decided to use purple heart with an oil finish. It has been over 1 year now, and I'm still very happy with my bed. If you click on my 48 link below you can see photos.
If I wanted to paint the bed, I would have made it from doug fir and saved a couple hundred dollars. Chris | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Yellow pine is readily available. | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | I'm having a really hard time tracking some down in the northwest and I only need about 35 sq ft (upper rails too) but all places require 100 or 200 linear feet at least... The bed will almost always be used just for show... I might try and find flooring planks... | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | You are haveing a hard time tracking down what? The north west is probably one of the richest areas for wood species in the US. While hard yellow pine is somewhat hard to come by here in Colorado, western pine, douglas fir, and western cedar are plentifull and cheap. You asked in the first post only about light colored wood. In the last post you mentioned doing a show truck. If you are doing an all original truck yellow pine coated with lamp black and oil is your only choice. If you have chopped up the truck into a rod, then a wood that when finished, complments the paint job would be the way to go. | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Sorry for being confusing. I'm wanting a show finish on the wood. Not going for a show truck, nor am I going for the rod thing. Wanting the yellow pine but keep it's natural color. I know I have plenty of choices, but the yellow pine really would pop against my red paint... | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you go HERE you can click the Product Locator link and find a dealer for Southern Yellow Pine in your area. I did a quick check and there are two dealers in Oregon, one in Lake Oswego sand another in Portland. That should get you started. Good Luck. EDIT: Mar-K also sells Yellow Pine board kits.
| | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | Southern yellow pine may be durable, rot resistant, and original (painted black), but if you want beautiful grain and figure then perhaps go with something else. Quartered white oak, ribbon striped mahogany, tiger maple, the list goes on.. | | |
