0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi there,
I am a beginner that is seeking some probably otherwise simple advice. I just started getting into classic trucks and purchased a 1954 3100 Chevy. A friend who knows about this truck helped me take apart the tranny so I could swap in a working motor.
I need help re-assembling the clutch fork to the bottom of the clutch pedal. My buddy is on sabbatical and I have no idea how this assembly works.
I have the fork in correctly and attached to the throw-out bearing. My difficulties are how to connect the threaded rod to the clutch pedal. I searched the threads here and consulted my manual but have had no luck with a drawing that describes this.
Any help would be great.
Carlos | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | It will help me, too! to get mine back together. thanks | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Tim,
This is a tremendous help, thanks for sharing. Two questions...
Is there a on either side of the clutch fork along the threaded rod?
Does the spring simply attach to the frame?
Thanks again, this is super helpful.
Carlos | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There is a U-shaped bracket riveted to the frame for the springs to attach to. | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | | | |
