0 members (), 83 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
Hi there,
I am a beginner that is seeking some probably otherwise simple advice. I just started getting into classic trucks and purchased a 1954 3100 Chevy. A friend who knows about this truck helped me take apart the tranny so I could swap in a working motor.
I need help re-assembling the clutch fork to the bottom of the clutch pedal. My buddy is on sabbatical and I have no idea how this assembly works.
I have the fork in correctly and attached to the throw-out bearing. My difficulties are how to connect the threaded rod to the clutch pedal. I searched the threads here and consulted my manual but have had no luck with a drawing that describes this.
Any help would be great.
Carlos
It will help me, too! to get mine back together. thanks
Tim,
This is a tremendous help, thanks for sharing. Two questions...
Is there a on either side of the clutch fork along the threaded rod?
Does the spring simply attach to the frame?
Thanks again, this is super helpful.
Carlos
There is a U-shaped bracket riveted to the frame for the springs to attach to.
Thanks Brad.
