0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#646990 05/16/2010 6:06 PM
On either side of the engine housing I have some white/bluish smoke coming out of the manifold area once the engine is going...probably a gasket leak? I'm thinking I may need to change out all the gaskets that I can.
Most likely cause is oil seepage from the valve cover and burning on the exhaust manifold. Clean the head under the valve cover and spray some foot powder on the head. You should be able to track the leak to the source.
-=JD=-
Motohack
"Hand me that BIG hammer"
1941 Chevrolet 4408
Thanks Motohack. I'll give 'er a shot.
