| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64697 08/22/2006 1:28 PM | Joined: Apr 2006 Posts: 19 Junior Member | | Junior Member Joined: Apr 2006 Posts: 19 | can anyone tell me some facts about a 1952 gmc 228. ive been looking everywhere. is it a good engine? please help me. Thank you | | |
#64698 08/22/2006 6:35 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What kind of facts do you want to know?
Yes it is a good engine. If you are wanting to put it in a Chevy you'll need to move your radiator forward. You'd be better off with a 270 or 302 if you are going to rebuild but if you can get a good running 228 worth the money, go for it. | | |
#64699 08/23/2006 5:53 AM | Joined: Apr 2006 Posts: 19 Junior Member | | Junior Member Joined: Apr 2006 Posts: 19 | is it better then a 235? will it handle highway speeds? | | |
#64700 08/23/2006 6:08 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I wouldn't say the one 228 I've had was any "better" than any of the 235's I've had - "highway speed" has to do with trans and rear end, not engine - any of these ol 6's are overworked above 50-55 with the usual trans and 3.90/4.11 rear gears
Bill | | |
#64701 08/23/2006 7:14 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Go here, there is lots of info for you. Also, join the discussion group for GMC answers that you may have on your truck. http://www.oldgmctrucks.com/index.html Cecil........ | | |
#64702 08/24/2006 3:01 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 228 is a pressure oil motor and most likely will out perform the 216 that was original in your '50 Chevy.
But if you are going to do the work to convert to a GMC motor why not look for a 270 or 302. 302s can be hard to find, but 270s are common and externally identical.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
