3 members (Hanks custodian, Steelonsteel, 1 invisible), 58 guests, and 0 robots.
Topics128,054
Posts1,055,780
#64697 08/22/2006 1:28 PM
Junior Member
Junior Member
can anyone tell me some facts about a 1952 gmc 228. ive been looking everywhere. is it a good engine? please help me. Thank you
#64698 08/22/2006 6:35 PM
What kind of facts do you want to know?
Yes it is a good engine. If you are wanting to put it in a Chevy you'll need to move your radiator forward. You'd be better off with a 270 or 302 if you are going to rebuild but if you can get a good running 228 worth the money, go for it.
#64699 08/23/2006 5:53 AM
Junior Member
Junior Member
is it better then a 235? will it handle highway speeds?
#64700 08/23/2006 6:08 AM
I wouldn't say the one 228 I've had was any "better" than any of the 235's I've had - "highway speed" has to do with trans and rear end, not engine - any of these ol 6's are overworked above 50-55 with the usual trans and 3.90/4.11 rear gears
#64701 08/23/2006 7:14 AM
Go here, there is lots of info for you. Also, join the discussion group for GMC answers that you may have on your truck. http://www.oldgmctrucks.com/index.html
Cecil........
#64702 08/24/2006 3:01 AM
The 228 is a pressure oil motor and most likely will out perform the 216 that was original in your '50 Chevy.
But if you are going to do the work to convert to a GMC motor why not look for a 270 or 302. 302s can be hard to find, but 270s are common and externally identical.
