1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
I have been studying the articles on the T5 swap and have 1955 chevy car rear end to use. Is the T5 avaliable in any years later than 1985 that will work? It seems to be getting hard to find the older S10s.
Riding in the Passing Lane
Yes. They used them on S-10's till about 94, but the 88 up had an electronic speedo drive. If you use one of those you need a converter (very expensive) or change the rear housing with one that has mech. drive (hard to find) or use an electrical speedo.
1972 Chevy c10 Cheyenne Super
FYI, the T5 was used in Ford, AMC, Jeep,GM and likely others I can't remember. It was also built in a lot of different gear ratios. I have a list that I'll look for. it is quite lengthy.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks for the info guysm any help is appreciated.
so how far back is the t5 5 speed w/ over drive and metric speedo in the s 10's? (yr rang)
They go back to about 1983. Be careful a lot of the early ones were 4 speeds. They look a like. The is a tag on all of them that is held on by one of the rear housing bolts. There are numbers on the tag. In the bottom left is a number 1352-xxx. Take this number & find a chart on the internet. It will tell you by this number what it came off of & the gear ratio's. The Camero is a good one to use but the shifter is way to the rear. You have to have bucket seats.
The earliest listing I for the S10 is 82. However you must be careful which one you get as the low gear ratios vary greatly. They all have a tag 1352-XX and those last digits tell the story. Many of the T-5's had 4:03 (4 cylinder & diesel) 1st but V8 Camaro/Firebirds had as high as 2:95 low gear. I show over 200 applications of this transmission with Nissan, Izuzu, TVR (?) and all the others I previously listed. Try to stick to the larger engine V6 S10's or V8 powered Mustangs, Camaro, etc. for the best application. Also watch out for the stick position as that might be a factor.
I can't comment on the metric speedometer but new electric speedo's work well and are not terrible expensive. All T5's are OD but that ratio varies too.
If you find a few jot down the tag numbers and e-mail to me and I'll look up the data for you. There are millions of them out there.
Dave
hey thanks so much this has been driving me nuts for days and sorry for the hi jacking on the tread. i found tons of them (s 10s) but did not what to ask to get the right trans like this one. http://montana.craigslist.org/pts/1709954670.html
but it is a 4cly
