5 members (KEVINSKI, FAST55, Hanks custodian, Otto Skorzeny, Rusted Nut), 66 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
#645476 05/11/2010 6:37 PM
I first joined the Stovebolt in 2002 when I purchased my 1950 3600 (3/4 ton) pickup.
Over the last 8 years I have made steady progess of tearing it down and rebuilding it.
I have replaced the old 6 cylinder with a 350 v8 and turbo 350 trans. I have raised it 4 inches and added many new parts.
Right now I'm in the process of a complete rewire with a Painless Wiring 12 circuit harness.
I have placed some photos here:
http://s671.photobucket.com/albums/vv72/tnasworthy/My%201950%203600%20Chevy%20Truck%20Project/
in case anyone wants to see where I started my project, and where I'm at today.
I'll continue to add photos as I progress.
MUCH THANKS to the STOVEBOLT crew. I've gained tons of knowledge here over the years.
503600Guy
Well, you've made great progress and I'm sure you will have a fun driver. A couple questions, first on your motor/ trans mounts, a kit or home made. Also did you have plenty of floor to trans clearance? I also have a 3600 and some day I may slip in a 292 and automatic trans.
Keep up the good work
Jim
1946 1/2-Ton Chevy
Looks like you are getting some good help with the project!
DAle
1949 Chevy 3100
More pix
I gave my mother great trouble but I think she liked it. ~ Mark Twain
I used an engine/trans mount kit. There's plenty of room for the turbo 350, but the firewall to HEI distributor clearance is tight. Still, it works fine. The only real issue to going with a v8 was having to reconfigure the steering box and front shock mounts. The v8 won't fit with the stock steering column, so I went with a power steering kit and a tilt column.
The front shock mounts have to be reversed (left side mount on right and vise versa).
