yes it's a 58 [hood emblem tells], that blue tag is just the GVW tag - the 'vin' will be on a small stainless tag spot welded to the drivers door pillar above the dogleg [starts with 3A, meaning 114" WB 1/2T or 3100], and it should be stamped on the top frame rail around the steering box, but the frame number will be missing the "3A"
the specific model is a 3116, with the clamshell end gate - the barn door style is 3106
