2 members (FAST55, Rusty Rod), 96 guests, and 2 robots.
Topics128,026
Posts1,055,404
Members48,422
#643898 05/06/2010 3:00 AM
Is there something in the filler neck that restricts fuel flow? When I try and fuel I have to trickle it in to fill up. Doesn't seem right. When I poured some in from the can it ran in pretty fast. I have tried different pumps/stations. Can't even lock it on the first click. I tried a search on fuel +splash.
I have the same problem, can't explain it, though.
Bill Burmeister
Automatic nozzles hadn't been invented in the 50's and the fillers weren't designed for them. On some models, holding the nozzle upside down will help.
Yeah, my truck likes to fuel up slowly as well, so does the car. It really only wants gas as fast as gravity feed, like from a jerry can. I have learned to just enjoy standing there and smiling.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Here is my humble theory;
The truck was manufactured when gas was 10 cents a gallon. The pumps then ran much slower and under less pressure. Now that gas is about $3.00 a gallon the oil companies want to get your money as fast as they can so they improved the pumps to deliver it faster under much greater pressure.
I have also noticed that the newer the gas station, the harder it is to get gas in my older cars and trucks.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
FriedGreen,
Actually pumps ran faster in the 50's than they do now. Federal law now puts a 10 Gal Per Minute restriction on dispensers for safety. Also, the age of the gas station does not make much difference. The same Red Jacket submerged pumps are used as were 25 years ago. The gallons per minute depends on how recent the filters have been changed in the dispenser. E10 tends to plug filters much quicker than clear gasoline.
Look at the bright side, the experience is taking longer so your cost per minute is lower.
Wde also are blessed with filler neck restrictors so you can no longer put a syphon tube down them.
I have an after market tank with no restrictions and it takes a long time to fill, can't use even the first notch and it splashes back.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Look at the size of the tube going from the fill neck to the tank. Stovebolt trucks always had a problem taking gas at high fill rates, at least since the late 1950's when I started pumping gas! A restricted vent system that won't let the air purge out of the tank easily will also cause the gas to back up in the fill neck- - - -the gas can't get in any faster than the air can get out!
Y
Y Offline
I just hold the pump out a little ways and at an angle, so the vent tube is away from the stream, and I have no problem on 4 stock 49 trucks. That is with the tank behind the seat. I hold the pump on rather than locking it on, but I could, I just prefer to stop when I hear the gas starting up the hose rather than letting the auto shutoff catch it. Besides- it doesn't take that long to put in 12 gallons.
Now I would hate to have to use those california type nozzles with the black sock over the pump nozzle. I had great fun with them on a motorcycle trip out there.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
