4 members (Ponchogl, TUTS 59, Otto Skorzeny, Hotrod Lincoln), 128 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
#64331 08/13/2006 4:33 AM
Apprentice
Apprentice
I've got a chevy small block crate motor in a 69 chevy pickup. It leaks pretty badly at the bottom of the timing chain cover(1/2 quart at each fill-up). I'm looking to replace the timing chain cover and install a new one. Any advice on ... which covers work best, gaskets, one piece or two piece, tips on replacement, would be greatly appreciated. Thanks!
I gave up golf for this!
#64332 08/13/2006 12:51 PM
ODSS Lawman
ODSS Lawman
Your leak can be from a number of things. First is a bad gasket. The most common thing is a bent cover. Take the cover off the engine and place it on a flat surface.
If the cover rocks, bend it flat, this may take some time and an assortment of hammers to get perfect.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#64333 08/13/2006 5:47 PM
Riding in the Passing Lane
Make shure its not the seal first. It can be replaced without pulling the cover. To really do a good job its best to pull the oil pan. You can usually reuse the cover like Green posted but sometimes the timing chain is so sloppy it wears through the side. A 2 piece cover is only nessesary if you make frequant cam changes.
1972 Chevy c10 Cheyenne Super
#64334 08/14/2006 12:41 AM
The best way to seal that up is to install an aluminum chain cover and oil pan. I finally put aluminum valve covers on one of my small block to fix a reoccurring oil leak. Hasn't leaked since,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#64335 08/17/2006 3:54 AM
Apprentice
Apprentice
Thanks guys!
#64336 08/18/2006 2:17 AM
They make 2 different front rubbers for the oil pan to the front cover.If they have installed the thin rubber when she needs the thick you will have a major leak .Easy way to diagnosis is leave some of the oil residue on the cover pan area and coat with some baby powder and fire it up and watch for the leak.They also make some stuff called leak trace and it comes in a aresol can you can do the same thing with.Good luck
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
