3 members (Shaffer's1950, Bill Hanlon, Hotrod Lincoln), 143 guests, and 3 robots.
Topics128,190
Posts1,057,339
Members48,469
Looking to get Mom's old Willy's 4x4 PU going.
It is mostly Chevy except for the body.
1 ton 8 lug axles, 350 engine, but I have to decide which trans to use.
Axle tag says 4.09, tires are 33".
Last drive train was a 350 and T-18 trans.
Mom's knee is not liking a clutch pedal so much these days.
I have a complete 4x4 drive train from an 85 1/2 ton.
I am concerned that with torque converter slip the 4.09 gears may be too low for highway use without having to rev the engine too high for decent mileage?
I tried out some gear calculators and it looked OK, but none of them gave a correction factor for the auto trans, or is that not actually an issue?
1957 Chevy 3600
At these prices I want my gas 100 octane, leaded, and my windshield washed!
It's not an issue if the calculator uses the final output of the transmission you intend.
1:1 or 1:76 or ? I wouldn't be concerned with slip. Of course you can lock up the converters if you feel it's necessary.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
