| | | Forums66 Topics128,188 Posts1,057,334 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 48 | Looking to get Mom's old Willy's 4x4 PU going.
It is mostly Chevy except for the body. 1 ton 8 lug axles, 350 engine, but I have to decide which trans to use.
Axle tag says 4.09, tires are 33". Last drive train was a 350 and T-18 trans.
Mom's knee is not liking a clutch pedal so much these days.
I have a complete 4x4 drive train from an 85 1/2 ton. I am concerned that with torque converter slip the 4.09 gears may be too low for highway use without having to rev the engine too high for decent mileage?
I tried out some gear calculators and it looked OK, but none of them gave a correction factor for the auto trans, or is that not actually an issue? 1957 Chevy 3600At these prices I want my gas 100 octane, leaded, and my windshield washed! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It's not an issue if the calculator uses the final output of the transmission you intend. 1:1 or 1:76 or ? I wouldn't be concerned with slip. Of course you can lock up the converters if you feel it's necessary. | | |
