1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Anybody buy a set from anyone besides ARP? They want $90.00 plus shipping for a set...ouch.
Hank | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hank, if the same bolts work on later 235's then ask for a later year at the local FLAPS and they can probably get them. Hope you got things straightened out from last night  Drop by when you have time and lets drink a cold..... PEPSI. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks Alvin,
Vendor has the info. We will see what happens, I feel like things will work out fine. I will let you know for sure. I did a little research and the mains having 30/1000 difference seems to be acceptable. That puts it back in the bearing area. I appreciate your mic. and time buddy!
Hank | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I didn't think ARP even made a kit for the 235! Or at least they didn't when I called them about it, which was about 10 years ago. Ended up matching the main bolts up at the local Deere dealer. Seems that head bolts from a Deere Deisel are an exact match.
Bill Burmeister | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | They make them Longbox,...they want way to much cash though. Didn't ask about the head bolts, didn't want to have take out a second mortgage after the first quote. Thanks for the Deere tip. I will keep that in mind. | | |
