| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 19 New Guy | | New Guy Joined: Nov 2009 Posts: 19 | hello people my question i am rebuilding two 235 engines to one the first had no oil filter and the second that i am going to use had a filter but i got it in parts . my question i can bolt on the filter and connect the oil lines to the engine . no problem . but the first engine had aldo a metal ling from the engine to the head .do i have to plug it or connect that also with a t in the lining ? is there an oil schedule somwhere ? if anybody can help me with that it would be nice greetz aj | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy desert, different methods were used to get oil up to the cylinder head over the years. It sounds like some has replaced one of the factory lines with something of their own design, in order to keep the engine running. The line which supplies the cylinder head should not be involved with the lines to and from the oil filter. The stock oil filter was a bypass type, that is, it only filtered a portion of the oil circulating through the engine, unlike the modern systems which filter all the oil before it goes to the engine bearings. There is a pressure hole near the rear of the block on the left [drivers] side which is the pressure port for the oil filter, the drain back port is closer to the center of the block on the left side. If you search the Tech Tips section you may find pictures of the installation, hope that helps. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The metal line to the center of the head on the outside was installed because the internal path was plugged up with sludge.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2009 Posts: 19 New Guy | | New Guy Joined: Nov 2009 Posts: 19 | Thanks guys
for the advice it is much clearer to me.
greetz from the netherlands
aj | | |
