3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#642119 04/30/2010 11:07 AM
hello people
my question i am rebuilding two 235 engines to one the first had no oil filter and the second that i am going to use had a filter but i got it in parts .
my question i can bolt on the filter and connect the oil lines to the engine .
no problem .
but the first engine had aldo a metal ling from the engine to the head .do i have to plug it or connect that also with a t in the lining ?
is there an oil schedule somwhere ?
if anybody can help me with that it would be nice
greetz
aj
3B Offline
Hy desert, different methods were used to get oil up to the cylinder head over the years. It sounds like some has replaced one of the factory lines with something of their own design, in order to keep the engine running. The line which supplies the cylinder head should not be involved with the lines to and from the oil filter. The stock oil filter was a bypass type, that is, it only filtered a portion of the oil circulating through the engine, unlike the modern systems which filter all the oil before it goes to the engine bearings. There is a pressure hole near the rear of the block on the left [drivers] side which is the pressure port for the oil filter, the drain back port is closer to the center of the block on the left side. If you search the Tech Tips section you may find pictures of the installation, hope that helps.
3B #642177 04/30/2010 4:01 PM
The metal line to the center of the head on the outside was installed because the internal path was plugged up with sludge.
My Blog
3B #642669 05/02/2010 9:24 AM
Thanks guys
for the advice it is much clearer to me.
greetz from the netherlands
aj
