1 members (klhansen), 107 guests, and 1 robot.
Topics128,062
Posts1,055,856
Members48,428
#641923 04/29/2010 9:58 PM
Does anyone know if the pertronix 40,000 volt flamethrower coil should be grounded to the chassis? I have a 1946 1 1/2 ton if that helps... Thanks
1946 2 Ton Flatbed
hot side to ignition, ground to points or electronic ignition trigger
Thanks.
1946 2 Ton Flatbed
I'm running the flamethrower coil with the petronix electronic ignition trigger. The coil is fine, but I'm not getting any power to the spark plugs. Suggestions?
1946 2 Ton Flatbed
