0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#641923 04/29/2010 9:58 PM
Does anyone know if the pertronix 40,000 volt flamethrower coil should be grounded to the chassis? I have a 1946 1 1/2 ton if that helps... Thanks
1946 2 Ton Flatbed
hot side to ignition, ground to points or electronic ignition trigger
Thanks.
1946 2 Ton Flatbed
I'm running the flamethrower coil with the petronix electronic ignition trigger. The coil is fine, but I'm not getting any power to the spark plugs. Suggestions?
1946 2 Ton Flatbed
