0 members (), 50 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
I
I Offline
i see a lot of posts about the vin but nothing about a frame location i bought a 53 in Indiana trying to register in Connecticut but was told they to see 2 matching vin# any one have any idea if there is one?
I think there is a number on the driver's door pillar and a matching engine number stamped on the engine near the distributor. It has been a while since I looked at those things.
1951 1 Ton Completed
First VIN is a legal concept with international support that didn't really take hold until the 80's. You have various serial numbers that do not match.
GM trucks in '53 has a body serial number in the driver's side door opening and an engine serial stamped near the distributor. Those numbers are not going to match.
You might personally research the CT law because I suspect it has provisions for old vehicles that your counter person isn't aware of.
I
I Offline
thank you i'll just have to bring it in and see what happens
When moving from Washington to Oregon, I had a determined state patrol worker spend about an hour and a half with my 50 Chev on a lift looking for some stamped number on my frame. (I did get a bit of free frame cleaning from his wire brush.) No amount of talking or manuals would convince him that he would find nothing and that the engine number on the old title was long gone. He finally gave up and the state assigned the body serial number as my VIN. Stamped in on a cheesy metalic sticker and stuck it to the door pillar.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
So on the 1948-55 1st, they are NOT also on the frame enywhere? Anyone know for sure?
Nothing would stop someone from putting a number on the frame, but the factory did NOT put the numbers anywhere on the frame.
I've looked pretty hard at a few of these frames and sure have never found reason to question the generally accepted statement that its not there.
I cleaned an painted my frame and no numbers it's a 52.
Pete
None on my 48, and I've seen every square inch of it, inside and out, up close and clean.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
There is no vin# stamps on the frames only the door pilar. I did however stamp both of my trucks frames with the vin# for theft reasons. I think it's totally up to you if you want to stamp the frame or not. Just my 2-cents worth...
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
I did a frame off on my 50' no numbers anywhere. Never thought about stamping the number on the frame myself? Might be worth it if the truck ever came up stolen and it was located. Remember the old fashioned theft protection of scratching your Social Security number in things (nobody uses that one anymore).
We go over this otopic pretty regularly.
Do a search on +frame +vin
Some states, such as CA required a frame-stamped ID. Someone stamped some frames but no one has posted definitive information about who did it (and for which years: maybe GM (in the Oakland assembly plant), maybe the dealer, maybe the state police, maybe the DMV, maybe ??.
