7 members (55Delray, Steve L., Bill Hanlon, MickeyP, WICruiser, Bucker, 1 invisible),
64
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 2 New Guy | | New Guy Joined: Apr 2010 Posts: 2 | i see a lot of posts about the vin but nothing about a frame location i bought a 53 in Indiana trying to register in Connecticut but was told they to see 2 matching vin# any one have any idea if there is one? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think there is a number on the driver's door pillar and a matching engine number stamped on the engine near the distributor. It has been a while since I looked at those things. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | First VIN is a legal concept with international support that didn't really take hold until the 80's. You have various serial numbers that do not match.
GM trucks in '53 has a body serial number in the driver's side door opening and an engine serial stamped near the distributor. Those numbers are not going to match.
You might personally research the CT law because I suspect it has provisions for old vehicles that your counter person isn't aware of.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2010 Posts: 2 New Guy | | New Guy Joined: Apr 2010 Posts: 2 | thank you i'll just have to bring it in and see what happens | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | When moving from Washington to Oregon, I had a determined state patrol worker spend about an hour and a half with my 50 Chev on a lift looking for some stamped number on my frame. (I did get a bit of free frame cleaning from his wire brush.) No amount of talking or manuals would convince him that he would find nothing and that the engine number on the old title was long gone. He finally gave up and the state assigned the body serial number as my VIN. Stamped in on a cheesy metalic sticker and stuck it to the door pillar. | | | | | Joined: Nov 2009 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 51 | So on the 1948-55 1st, they are NOT also on the frame enywhere? Anyone know for sure?
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Nothing would stop someone from putting a number on the frame, but the factory did NOT put the numbers anywhere on the frame.
I've looked pretty hard at a few of these frames and sure have never found reason to question the generally accepted statement that its not there.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I cleaned an painted my frame and no numbers it's a 52.
Pete | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | None on my 48, and I've seen every square inch of it, inside and out, up close and clean.
Grigg | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | There is no vin# stamps on the frames only the door pilar. I did however stamp both of my trucks frames with the vin# for theft reasons. I think it's totally up to you if you want to stamp the frame or not. Just my 2-cents worth... | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I did a frame off on my 50' no numbers anywhere. Never thought about stamping the number on the frame myself? Might be worth it if the truck ever came up stolen and it was located. Remember the old fashioned theft protection of scratching your Social Security number in things (nobody uses that one anymore). | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | We go over this otopic pretty regularly.
Do a search on +frame +vin
Some states, such as CA required a frame-stamped ID. Someone stamped some frames but no one has posted definitive information about who did it (and for which years: maybe GM (in the Oakland assembly plant), maybe the dealer, maybe the state police, maybe the DMV, maybe ??.
