0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#640725 04/25/2010 2:57 PM
Hey guys quick question. Do all the 47 to 53 chevys use the same spindles and what ones interchange thanks
flynnskfx #640869 04/26/2010 2:06 AM
Within size ranges they use the same spindles.
OldSub #640914 04/26/2010 5:39 AM
King pins from 1/2 to to 2 ton are the same, for information.
ABento #641268 04/27/2010 4:38 PM
Ok I am learning. If its the same king pin then 1/2 ton spindles would fit a 2 ton suspension? I am looking at converting the 2 ton to 1/2 ton front end, so I am trying to find differences in the 2ton to 1/2 ton.
flynnskfx #641303 04/27/2010 6:46 PM
There were 3 different axles and therefor 3 different king pins during these years. 1/2 ton, 3/4 ton to 1 1/2 ton and 2 ton. Axle tread width is different as well.
crenwelge #641348 04/27/2010 10:22 PM
In addition to load handling ability, the Ackerman angle is different for any track width and wheelbase configuration. Rule of thumb is: lines drawn through the center of the kingpins and the tie rod connections should converge where the vehicle centerline intersects the rear axles.
Even minor changes in front end design geometry will increase steering effort and compromise tire life.
-=JD=-
Motohack
"Hand me that BIG hammer"
1941 Chevrolet 4408
Motohack #641460 04/28/2010 5:39 AM
According to Rare parts they tell me king pins are the same from 1/2 to 2 ton.
Spindles would not be the same, most l9ikely each had its own spindle
ABento #641471 04/28/2010 7:20 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Then Rare Parts is wrong, because there are 3 different size king pins for the different size models of trucks being made.
Look HERE on this web page for the info...joe
#641483 04/28/2010 11:08 AM
to expand on his queston alittle reguarding spindles i recently got a 50 chevy front axle complete axle itself is an exact match from every messurment i can check for my 39 spindles i will assume are different but i have a disk brake kit for my 39 is there a way i can use the spindles from the 39 on the front axle of the 50 "axle tie rods ect.. are chrome on the 50"
1937 1/2 ton
Daniel Bland #641766 04/29/2010 5:56 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Dan the 39 & 50 spindles/axles use different king pins, so unless you modify something it won't work. Have you tried just bolting the 39 kit on the 50 axle to see it'll bolt on?? You may just have to modify the bolt holes & use different bolts to make it work..joe
#641829 04/29/2010 2:31 PM
yeah i tried to see if the kit would bolt on but it didn't appear the bolt holes lined up and if thats different i am guessing the spindle taper that the new bearings will have to fit would be different also frown guess i will just have to buy another kit for a 50 and be stuck with a 39 kit i can't use lol such is life smile
1937 1/2 ton
