0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 10 New Guy | | New Guy Joined: Apr 2010 Posts: 10 | Hey guys quick question. Do all the 47 to 53 chevys use the same spindles and what ones interchange thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Within size ranges they use the same spindles.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | King pins from 1/2 to to 2 ton are the same, for information. | | | | | Joined: Apr 2010 Posts: 10 New Guy | | New Guy Joined: Apr 2010 Posts: 10 | Ok I am learning. If its the same king pin then 1/2 ton spindles would fit a 2 ton suspension? I am looking at converting the 2 ton to 1/2 ton front end, so I am trying to find differences in the 2ton to 1/2 ton. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | There were 3 different axles and therefor 3 different king pins during these years. 1/2 ton, 3/4 ton to 1 1/2 ton and 2 ton. Axle tread width is different as well. | | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | In addition to load handling ability, the Ackerman angle is different for any track width and wheelbase configuration. Rule of thumb is: lines drawn through the center of the kingpins and the tie rod connections should converge where the vehicle centerline intersects the rear axles.
Even minor changes in front end design geometry will increase steering effort and compromise tire life. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | According to Rare parts they tell me king pins are the same from 1/2 to 2 ton. Spindles would not be the same, most l9ikely each had its own spindle | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | According to Rare parts they tell me king pins are the same from 1/2 to 2 ton. Then Rare Parts is wrong, because there are 3 different size king pins for the different size models of trucks being made. Look HERE on this web page for the info...joe | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | to expand on his queston alittle reguarding spindles i recently got a 50 chevy front axle complete axle itself is an exact match from every messurment i can check for my 39 spindles i will assume are different but i have a disk brake kit for my 39 is there a way i can use the spindles from the 39 on the front axle of the 50 "axle tie rods ect.. are chrome on the 50"
1937 1/2 ton
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Dan the 39 & 50 spindles/axles use different king pins, so unless you modify something it won't work. Have you tried just bolting the 39 kit on the 50 axle to see it'll bolt on?? You may just have to modify the bolt holes & use different bolts to make it work..joe | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | yeah i tried to see if the kit would bolt on but it didn't appear the bolt holes lined up and if thats different i am guessing the spindle taper that the new bearings will have to fit would be different also  guess i will just have to buy another kit for a 50 and be stuck with a 39 kit i can't use lol such is life
1937 1/2 ton
